diablo help
Old 03-13-2005, 06:56 PM
Tmoney's Avatar
Exclamation diablo help
well my plug wires got torn out when i pulled it out of the obeII pot and then i got the wires soildered back to the plug but now the it dosent work it keeps saying the ignitions not on but it is well during the time i pulled the wires out i took off the egr soilnoid so i dont think it had anything to do with it but maybe soo any elese had this problem
Old 03-14-2005, 12:52 AM
67Firebird455's Avatar
I just posted about the same thing, pulled the 3 leads out of the connector, green, grey and white. Did you ever get it to work, if so, which wires did you solder where?
Old 03-14-2005, 04:24 AM
Tmoney's Avatar
No but I looked at my friends wires and got it soildered back together but still dont work get the ignitions off code help anyone
Old 03-14-2005, 11:19 AM
2001NBMZ28's Avatar
You might have blown the "CIG ACCY" fuse when the wires came loose - same fuse powers the DLC.
Edit: Just re-read your post. If the Predator is powering up it's not the CIG ACCY fuse - I'd check the others though.
Old 03-14-2005, 01:35 PM
Tmoney's Avatar
Well it powers up and dose everything its sposse to do till i try to tune or run codes then it wont do it dosent get a signal from the ignition
Old 03-14-2005, 02:24 PM
2001NBMZ28's Avatar
You may need to give diablosport a call, or post in the product support section at www.diablosporttuning.com/forums/
