Time for longer wheel studs... any suggestions?
Right now.... stock wheel studs in front.
I run Weld drag lite 15 X 3.5's with a 5/16th spacer along with the weld draglite lug nuts.
Local track (e town) says this is fine...
Another track (island) tells me I need longer wheel studs.
Might as well be safe...
What size wheel studs/ open end lug nuts would you all recommend?
Thanks!
Thanks!
Originally Posted by DietCoke
With a spacer only the GM long stud is long enough to technically be nhra legal.
Ya they will just nock a hole in er! J/K i just put arp's on the frt of mine for 22.00 bucks. just do it & be safe. I used stock open lugs on my crager ss's for the street. Doesnt look the best but will work for now. Lets go RACING!
Originally Posted by mdblackz28
the part number from JNorris is right. below is a pic. you can order them at http://gmpartsdirect.com/, for $1.39 a piece.
Be carefull w/these if you're running any kind of spacer. I was using these w/ 7/32" (~3/16")spacers on the rear w/15x10" 7.5"BS DragLites. Bent all 10 studs after only 1/2 dozen or so launches. As stated above... they are NOT hardened.
