CCW's 505A
Old 03-14-2005, 02:09 AM
SLP LS1's Avatar
Default CCW's 505A
I'm thinking about buying a set of ccw's 505A. They look really great! Heard a lot of people go 10" in front and 11" in back? On a 19" wheel. What size should I go with? Is there anything else I need to know about ccw and this type of wheel? http://www.ccwheel.com/demo/files/wh...el.php?id=505a
What do you guys use to clean 6061-T6 Aluminum on these rims?
Old 03-15-2005, 06:05 AM
SLP LS1's Avatar
bump....
Old 03-15-2005, 07:40 AM
VSGLS1's Avatar
Go 19x10 up front & 19x11 out back. They look really good like that with the staggered lip. I am still searching for what I want to use on these wheels.
Old 03-15-2005, 09:26 PM
Shuck's Avatar
How much does a set of those run?
Old 03-16-2005, 08:45 AM
Quick 99's Avatar
$2400, you can only get them 19x10 fronts and 19x11 rears, but i've heard rumors that they will be making an 18" for the fronts, but optionally you could order a set of 18" all the way around because it would fit.
Old 03-16-2005, 10:57 AM
VSGLS1's Avatar
You can go 19x10 all around, 19x10/19x11, 19x10/20x11.....Call them and bounce some ideas off of John, he is very helpful.
Old 03-17-2005, 12:22 PM
SLP LS1's Avatar
Thanks guys, these are probably the best looking wheels I've ever seen for the f-bodies. At least that is what I think!!!
Old 03-18-2005, 10:59 AM
tump's Avatar
Expect to shell out 4 Thousand dollars for a set ot CCW wheels with tires.
Old 03-18-2005, 07:41 PM
Chased's Avatar
4000 g's is right but its well worth it
