Strange 12 bolts on sale!
Another March Madness offering from TBYRNE Motorsports. We have the Strange 12 bolts on sale though Sunday evening (March 27th) -
Strange 12 bolts -
PRG210-PRGOP8 - Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) - Regular price $2429.99 - sale price - $2229.99
PRG210-PRGOP-14 - Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) - Regular price $2429.99 - sale price - $2229.99
Options -
R5206 Upgrade to aluminum support cover $149.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings.$229.99
gmbbpcore - Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars..$229.99
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763). Discounts can not be combined. Be sure to note where you saw our ad so we know where our advertising dollars are working!
ORDER LINE - 1-877-4-TBYRNE (1-508-636-0770 in MA)
E-MAIL - tbyrne@tbyrne.com
NEW WEEKLY SPECIALS CAN BE SEEN ON - OUR WEBSITE
Strange 12 bolts -
Options -
I might be wrong but this should be pretty clear -
This has to be done to keep your traction control.
I see what you mean. Part of that should be seperate so it doesn't look like it's part of the option for $229. Strange needs to take the reluctors off of the axles to build them into the new rear. I wish we could get them seperate. That would make life alot easier!
