What MPH shifts for 342 gears with an automatic?
Old 03-14-2005, 07:13 PM
02 Pewter LS1's Avatar
Default What MPH shifts for 342 gears with an automatic?
I just ordered my Moser 12 bolt with 342 gears and need to know the MPH shift points? I will be using Flashscan to make the changes. Thanks for the help guys.
Old 03-14-2005, 09:10 PM
Moderator
jimmyblue's Avatar
http://home.cfl.rr.com/jimmyblue/PCM_Trans_20041024.xls
Old 03-14-2005, 09:22 PM
Thanks Jimmy
Old 03-14-2005, 09:23 PM
Pontiacerator
RevGTO's Avatar
If Flashscan is like HP Tuners, then it will scale for the shift points with the rear end gear change. You can start there and then adjust with Jimmy's numbers, rather than typing in all the numbers individually.
