mounting the WOT switch?
Take your bracket. Bend it like the directions say, cut off the end of it, and then mount it on your throttle body with the switch on it. When you go WOT it should then, and only then, be activated. Some guys mount it under the gas pedal as well. Make sure that it won't hold your throttle wide open. Be sure it will NOT get hung.
