Dowel Rods?
Originally Posted by DJB
Where can I buy the 5/16 rods to hold the lifters up? How do I need to modify them to make them work?
I bought mine at a steel shop. You should have on near you, one that specializes in bolts and stuff. Make sure that they are longer than your cam!!!
About 2 feet. I used a grinder and I made both of mine flat on one side because I had trouble getting them in either side. After they were grinded, like cake!!! Also make sure that you don't bump on out ANY while taking the cam out. Hope this helps.
Originally Posted by Red99TA
Any hardware store should have them (the wooden ones). I sanded down the side of the one that I used on the driver's side so that it was flat instead of completely round. Just used a file to do this since the wood is so soft to begin with.
