How will a car run....
I notice a lot of carbon build up on my plugs which it is a symptom of running too cold a plug on motor. It just forces you to change the plugs often, which is always a good thing for nitrous anyway.
Originally Posted by Phil99vette
How will a car run on the motor back and forth from the track if its say setup for a 250-300 shot with pulled timing and colder plugs? I am trying to figure out if it is feasable to drive to the track with this setup.
Phil
Phil
In cold weather, the cold-start enrichment (CSE) is especially hard for cold plugs to take so I use a CTS tricker box to get out of CSE as soon as possible which is normally a minute or two.
I vote for plan B. Get a trailer. There are two advantages.
1. If something brakes, and it will over time, you have a way of getting the car home.
2. You have a perfect excuse to go buy a new truck
