PE Tuning?
PE = Performance Enrichment. When you go WOT (or anytime driving under heavier loads and TPS) you enter PE mode. The PCM then adds additional fuel to richen the mixture up (ideally it should be 14.7:1 / PE scalar = requested AFR , but unless the VE table is 100% on the ball this isn't exact)
I have no idea why I said performance enrichment... Power enrichment is what I've always heard it as... I must have been reading something else when I typed this response heh...
Originally Posted by RedHardSupra
i wrote up something the other day on the topic, might wanna take a look: http://redhardsupra.blogspot.com/200...universal.html
Originally Posted by Sotiri
Is it the same as open loop?
Originally Posted by white2001s10
Not neccessarily. It's a modifier that adds fuel similar to the coolant temp enrichment table, except it's based on load & RPM instead of coolant temp. It's another fuel adder that is triggered by changing load conditons such as going WOT.
So the only time it is in open loop is at startup? Why do people say it goes into open loop at WOT?
Open loop basically means it's not using the O2 sensors to determine fueling. It's relying on built in tables (VE and PE amongst them) and calculated Load values from the MAF and MAP to determine how much fuel to add
PE is enabled when TPS is > xx% depending on engine coolant temp and other variables
You won't get any learned fueling corrections so you'll have to do more work on the fueling tables.
If you also eliminate the other variables that affect fueling, then yes it would be more consistant, but simply running open loop does not automatically eliminate them... only the learned fuel trims.
LS1TECH Sponsor
Originally Posted by 94white28
what are the advantages of running an Open loop only tune???
For instance you want to eliminate the coolant variable in the range of 140*F and 200*F, then you have to make all those cells the same number to zero out the variance so changing coolant temp will not change the fueling. It's not automatic.
edit: maybe I'm not understanding your last post, sorry if that's the case.
