408ci and TH400 combo = 70mph @ 4000rpm. Can I safely drive at this high of an RPM?
Old 03-17-2005, 12:13 PM
MeanWS6's Avatar
Default 408ci and TH400 combo = 70mph @ 4000rpm. Can I safely drive at this high of an RPM?
With my 408 and th400 4K stall combo, I took it up to 70MPH and it was at 4000rpm, I quickly got off the highway and took side roads home.
But will I damage anything (springs, etc) by reving it this high for an extended period of time/miles?
Old 03-17-2005, 12:15 PM
technical's Avatar
What rear gears?
Old 03-17-2005, 12:20 PM
Slow Z28's Avatar
i figure with today's technology, and yesteryear's transmission, i'd be ok. considering that most people had a Th400 behind a big block back in the 60's and 70's
Chris
Old 03-17-2005, 12:21 PM
MeanWS6's Avatar
3.73's - I was on nittos/stock rims
who knows if my speedo is correct
Old 03-17-2005, 12:24 PM
Camaro_Zach's Avatar
you absolutly put more wear on the valve springs, so if you have a HUGE cam, id replace them once a season, $200 is cheap insurance. that is, id replace them every season if you do a lot of 4000rpm driving for long disanctes often. if its just once or so a month it sees highway duty, then every other season should be fine. i have a 400 in mine and i replaced the springs after one season but i also had a g5x3 which is hard on the springs period.
edit, i just noticed, we have the identical trans setup, same stall and everything. if you havent had it to the track yet, youre in for a big suprize. haha i love this trans!
Old 03-17-2005, 12:32 PM
technical's Avatar
4k stall and 3.73's will definitely keep the revs up, but 4k@70mph sounds a little high. Are you sure it shifted into third?
Old 03-17-2005, 12:45 PM
MeanWS6's Avatar
cam specs are 238 244 .605 .612 112 + 4
Yes, I was sure it's in 3rd; 1st and 2nd gear is useless. I am in them for about 2 seconds before I need to get into 3rd gear
My speedo has to be off
Old 03-17-2005, 01:04 PM
Flaminchiten67's Avatar
Was there any traffic? if so were you flying by them? keeping up with them? getting passed by semi's?
My 67 with 400 (pontiac) and th400 cruises at ~3k with 3.55 rear gears, with the stock 14 inch rallye 2's.
I would get back on freeway and try to pace with someone where you can see their speedo or have someone pace in front of you.
Old 03-17-2005, 01:12 PM
Bo White's Avatar
3.73s with a 26" tire with a "good" converter will be 3500-3700 rpm at 70 so your speedo is a little off. 4.10s will be 3800-4000 at 70, at least thats what it has been with the cars I have had. You should be fine, the engine will let ya know if it doenst like it- the water or oil temp guage will let ya know that.
Old 03-17-2005, 01:19 PM
obZidian's Avatar
it seems to be a bit off. try to get your speedo checked with a tap software or pacing someone you know. i wouldnt drive for to long on the hw like that....it just to much premature wear on your motor, no matter wat kind of materials used..
MeanWS6's Avatar
no, it was 2:30am - no other cars
I will have someone pace with me, as soon as this damn weather clears up.
Old 03-17-2005, 02:12 PM
black_z's Avatar
Damn that would be annoying.
Old 03-17-2005, 03:16 PM
Brian2001SS's Avatar
What about the gas mileage at that rpm!!! You will go broke if thats your daily.
Glad I got a mn6
Old 03-17-2005, 03:19 PM
no th400 ls1 car is a daily driver. at least i hope to god no one would do that.
gas is fine as long as you arent on the highway.
i got a 4k stall, trans brake, manual valvebody, 4.11 spool, i wouldnt have it any other way on a drag car. i love it.
oh and fyi, gas is the least of my expenses when owning a race car haha. seriously.
Old 03-17-2005, 03:40 PM
Mike94ZLT1's Avatar
Why dont you look into one of those gear vendors overdrive units?
Old 03-17-2005, 05:40 PM
Birdie2000's Avatar
70 mph was roughly 3800rpms in my TH-400 with 275/40/17's and 3.73's, right at my stall speed, so it doesn't seem that far off.
Mike, while nice, they make a heavy trans even heavier, and are a bit over $2,000 if I remember correctly. I'd look into a 4l80 before I dropped that kinda coin plus the cost of the original built trans.
Old 03-17-2005, 10:41 PM
obZidian's Avatar
i just spoke to a guy on the 4l60.com site, anyways, he told he can build me a 4l80e with all the needed hardware, capable of 1000hp, for 5K...i think if your gonna spend tons of cash for a 1000hp motor might as well go for a bullet proof tranny....
Old 03-17-2005, 10:50 PM
The turbo 400 is about as strong as they come, and a lot less than 5k, and weighs a lot less than a 4l80. Just no overdrive. The strength of the tranny is not an issue the issue was he felt like it was turning really high rpms for the speed.
Quick Reply: 408ci and TH400 combo = 70mph @ 4000rpm. Can I safely drive at this high of an RPM?
