Pushrod Length
Old 03-17-2005, 07:54 PM
Racer8102's Avatar
Default Pushrod Length
I am trying to install Patriot shaft mounts. Using comp r lifters, and a tsp 233/233 cam, when setting rockers on the stands with the 7.4 length pushrod, and with the lifter on the back side of the cam, the rocker shaft is sitting off ot the stand about 3/16 of an inch or so, with the adjuster screwed all the way out. Any Ideas, shorter pushrods, shim the stand or what? What is the proper way to do this and keep geometry correct. Need help ASAp
Old 03-17-2005, 09:24 PM
Racer8102's Avatar
I did some searching and found that I will need a shorter pushrod (Like 7.050-7.100 Instead of the TSP 7.4;s I have). So I will try and find a place that sells the shorter pushrod, oh and tell the wife I wasted another 100 bucks on parts that won't work!
Old 03-18-2005, 05:43 AM
Byter's Avatar
Try www.thunderracing.com
Old 03-18-2005, 09:54 AM
Unaffliated Racing's Avatar
It will probably end up being closer to 7.00". You will have to elongate the hole in the heads and they won't clear a stock valve cover with those DRE rockers.
Old 03-18-2005, 11:23 AM
Racer8102's Avatar
I've got the taller valve covers, but where do you get the shorter pushrods. Thunder's site doens't show anything that short. I would think that when I bought the patriot heads and rocker assembly from patriot they would have told me I would have to use a shorter pushrod, I guess not, and now reading the thread about the spark plug holes being messed up I am beginning to wonder! You do get what you pay for huh!
Old 03-18-2005, 12:40 PM
They wouldn't sell very good if they told you that you need shorter pushrods and the heads had to come off the motor to elongate the pushrod holes, which is typical of any true shaft rocker.
Old 03-18-2005, 01:16 PM
Racer8102's Avatar
where would i look to get some shorter pushrods?
Old 03-18-2005, 01:23 PM
P Mack's Avatar
Try emailing ed curtis.
Old 03-18-2005, 01:57 PM
BradWS6's Avatar
Summit Racing. 1-800-230-3030
Old 03-18-2005, 02:00 PM
Racer8102's Avatar
Just talked with Texas speed, they are going to get me the correct length, and trade me out. What a top notch opertation and taking care of their customers. Hopefully it will work out this time!
Old 03-18-2005, 02:10 PM
bad0211secws6's Avatar
.030 shims for 8 bucks thru summitt worked for me
Old 03-18-2005, 04:55 PM
Racer8102's Avatar
Did you shim the stand or the bolts that hold the shaft?
Old 03-18-2005, 09:48 PM
under the pedestal i was told this by the guy i bought the heads from and louis from lg motorsports worked perfect and only cost me 8 bucks
