Cars with cages
Cars with cages
I want to sit in few cars to see how each brand of cage fits me. Any volunteers? I want to check things like if the seats both go all the way back, where the side bar hits, head room, what needs to be cut....lemme know.
I've seen a lot of them, but I never sat in any of your cars.
You can sit in mine anytime mark, just let me know.
Tech Addict
I can only speak for mine but the fit is perfect. The side bars are angled around the arm rests as close as you can get them, the hight of the bar that wraps over the seats is like 1/4 a of an inch from touching the head liner. Prepare to puul you interior out if you get the solid cross bar.
Here is a link to more pics... Wolfe Roll Craft
The only issue I had is the door bars gor sctatched and I had them repowdercoated.
In this pic my seat is all the way back and not tilted at all so there is prob 8in to recline before hitting the cross bar.
This design where the bars go through the speaker grills not where the deck matt is still allows room to store items there.
Thanks guys. And I do NOT want the keys in the car when I check it out. I wanna keep living the illusion that my car is faster.
That is a bolt-in, right Todd? How much did it cost to get it powder-coated? So you are saying the front seats need to come out for a solid cross-bar? (which is required by NHRA) The back seats will likely be coming out for good when I put one in.
Tech Addict
It is a bolt in. You will need to remove the seats to get the solid cross bar cage in. T byron sells them.
Here is a link to WolfCraft
Originally Posted by Todd2001SS
It came powder coated, I re coated the swing bars because they were scratched from me getting in and out.
Tech Addict
Originally Posted by B-RAD2
what did u pay for the set up? i want one for my car. did u install it your self??
I have had mine for 3 years now, I paid $840 shipping included back then.
FWOL330
F-Body 6-Point Roll Bar, Mild Steel Bolt-In
Crossbar Option : Removable Crossbar
Door Bar Style : Low Slung (Std)
Powder Coated : Black (Std)
Rear Bar Option : Thru Side Plastic to Wheel Well (Std)
Shipping Option (Roll Bar & Roll Cage) : Shipping to Business (USA)
Swing-Out Option : Driver & Passenger Door
HERE is the page with some of my pics. This is the design many of us use. When i cam up with it the main concerns were for it to be legal and as un-noticed as possible. Unless you try to recline your seats you do not even know it is there.
I went with a double front bar to keep my twisting car in one piece. Cost was $240 for the kit and $70 ea for door swing kits. Install was easy and I have been very happy with it. NHRA now mandates bars be bolted in so the swing out part s moot. I just put the door bars into race and take them out when I get home
FWOL330
FWOL330
Tech Addict
so no rear speakers
todd your cage is sweet. I wish mine looked that pretty.
mark mine is mounted a little more foraward than todds is, with the stock seats you would have to sit pretty straight up, but with mine its within all the measurments of the nhra, also the seat plays into it just a little bit. When you run the stock seat you are technicly not legal, b/c your seat has to be supported at the back to the cross bar. You also have to take into account that your head has to be no more than 6 inches from the top of the bar. there are also some other things you need to look at. I will even let you take it for a spin, that is if you can fit into the seat
Tech Addict
Tech Addict
Originally Posted by CHarris
It's more about the installation than the kit you choose.
I think all of these have good points, and bad points. I just need to sit in a car with them & see what "feels good" to me. And hopefullly the one that meets all the requirements for what I want to do will feel ok too. Does it EVER work out that way?
[QUOTE=WAHUSKER Does it EVER work out that way?[/QUOTE]
Well it CAN work out that way. Unfortunately it usually costs a little more $$ to make sure it does. A cage is so permanent ( even a bolt in is not something you take out for a weekend cruise ) that you need to make sure you get it right the 1st time. Your a thorough enough guy that I'm sure you'll do exactly that
I did how ever learn very fast(like on the way home) that I needed two mor bars. So this advise is from experiance. What ever cage you put in make sure you tie into the Shock towers in the back as you see in my Pic's. they make a HUGE differance
Thanks for the words Todd!
