*dynograph* am i safe to run nitrous?
my air/fuel starts at 13.1 then 13.3 (im trying to read the dynograph) then starts going down to 12.1 then at wot looks like 12.3
am i safe to run 150 shot of nitrous?
I think you should worry about getting that car tuned right OFF spray before you spray it.
What is done to your car? And what hack tuned it? (no offense meant)
It also depends on what nitrous kit you have. If it's wet, you should be okay simply by just upping the fuel jet a little too compensate for your already "earlY" lean condition.
If you have a dry maf kit, I'd be a bit more carefull although you "might" still be okay.
A tune wouldn't hurt, but yes you can add the bottle onto what you've got now. Just run colder plugs and keep the coolant temp down below 200*F.
what are your other mods?
i put a cutout right after my passenger side's cats which i think caused me to lose 9 hp. so i gonna try and move it to the i-pipe. do you think this will change my air/fuel ration?
lid, k&n, free ram air mod, ngk-tr6, taylor spark plug wires, and the cutout.
of course it will.
If the wideband was installed after the cats, then you cannot get an accurate A/F the engine is running at.
So I ask again, how was the A/F tested?
Originally Posted by white2001s10
of course it will.
sorry i tottally just went around your question, it was after the cats. they stuck it in my cutout.
You were probably running in the mid to bottom 11:1 AFR range,
and like I said earlier, you're fine to put the bottle on.
I highly suggest getting rid of the cats first.
Originally Posted by Phoenix57
did they stick the meter up past the cat, and just used ur cutout as an entry point? y would you have a cutout on only one side?
