Conversions & Hybrids - cooling system
View Full Version : cooling system
RFERG43
03-21-2005, 12:49 PM
I'm starting on the cooling system in my LS1/RX7 conversion. The only radiator I could find to fit has the bottom hose connection on the passenger side and the top on the driver side. I am thinking of routing the top hose down and under the radiator to the pump outlet so that it won't interfere with the air intake plumbing. That would be about 56 inches of hose. Anyone see any problems with the long run of hose? Any comments would be welcome !!
LS1Sandrail
03-21-2005, 01:04 PM
I run about a 60" long hose to the radiator on my car and have not had any problems.
I fabricated the hose out of mandrel bent exhaust tube sections and use 6" radiator hose connectors at either end. I think I will upgrade to the silicon hose the turbo guys use eventually.
My radiator does not have a drain provision, so I put a plug in the tube to drain the radiator for service.
Hope this helps,
Phil
LS1Sandrail
03-21-2005, 01:06 PM
You might also consider having the inlet and outlet moved. It isn't all that hard for a radiator shop. If it is aluminum, you might have to find an experienced weldor to put new necks in and cover the old hole and make it look good.
Stu Cool
03-21-2005, 02:08 PM
If you want a real clean installation you can have a radiator built to your specs. Tell them what you need to cool and they will build it. The cost is really not that outrageous. Here is one builder to check with, there are others, including some site sponsors I'm sure:
http://www.streetrodstuff.com/Products/157/
Pat
RFERG43
03-22-2005, 07:39 AM
Thanks for the replies. Guess I'll try the long hose under the radiator.
