A4 shifter hard to shift from park
Old 03-21-2005, 04:24 PM
QUICK305's Avatar
Default A4 shifter hard to shift from park
A few weeks ago the shifter in my A4 started acting up. It almost seems like the switch that is activated by pressing the brake pedal is failing. I can press the button in, but the shifter will not move. It doesn't do this all the time, but when it does, it takes several minutes to manipulate the shifter into gear, and it's become quite an annoyance. Anyone ever heard of a "switch" failing?
Old 03-21-2005, 04:29 PM
luvmeZ28's Avatar
mine kinda has the same problem. it really rough to pull out of park, and i have to fidgit with it just right to get into reverse. any ideas?
Old 03-21-2005, 08:14 PM
Pontiacerator
RevGTO's Avatar
Yep, it's the brake interlock solenoid. It's located under the console by the shifter.
Old 03-21-2005, 09:03 PM
ALBurgZ28's Avatar
I am having the same problem. Would replacing it fix the "searching for reverse" or is there anything else to do?
Old 03-21-2005, 09:17 PM
Pontiacerator
RevGTO's Avatar
You can replace it or just unplug it ... of course, if the latter, then you're without this critical "safety" feature.
Old 03-21-2005, 09:42 PM
Z28_Ninja's Avatar
i had this same problem with my 1994 t-bird. when i would first shift it it was hard, but after the first shift it got easier until it sat for and hour or so, then it would do it again, and it ends up that i got liquid into the shifter and the grease that was on the mechanism washed off. all i did was remove the console and apply some grease that i got at work to the slides and it was nice and smooth again. not sure if the camaro has the same problem but it is an option.
Old 03-22-2005, 06:08 PM
prostock_bigblock's Avatar
You`ve got it .
Old 03-22-2005, 08:41 PM
QUICK305's Avatar
Thanks for the replies guys. Today it got so bad that I could NOT shift the car from park, so I had to pull the upper console right in the parking lot. Works fine now.
Thanks!
Old 03-22-2005, 11:56 PM
Blacker's Avatar
That was my problem about 2 years ago.
