Is this all i need to put 410's in a 10 bolt??
Old 03-21-2005, 08:40 PM
BTLFEDSS's Avatar
Default Is this all i need to put 410's in a 10 bolt??
I am planning on throughing some 410's in the 10 bolt.I am planning on buying GM 410's and a Motive master install kit.Will these to be compatable and is there anything else i would need
BTLFEDSS
Old 03-21-2005, 10:41 PM
1320_PERFORMANCE's Avatar
Strange 4:10 gears, T/A stud and girdle kit, Solid pinion spacer, redline oil w/ gm LSD additive, still holdin up after 2 seasons of racing....But strange 12 bolt is on the way....
Old 03-22-2005, 05:20 AM
BTLFEDSS's Avatar
To the top,whats up with solid pinion spacer???What do i need to buy and don't say a 12 bolt,cause i don't have the money for it
Old 03-22-2005, 05:56 AM
ace68's Avatar
thunder racing sells the solid spacer you have to set your pinion first to know how much of a shim you need and get a cover weld your tubes. aftermarket axel shafts. I'm into my rear right now for: 250-gm gears and install kit, 77-cryo treat gears, 150-TA cover 260-for axels, I still need fluid. 737 total. and solid spacer when I set them in this week. no labor i work cheep
my ta cover i got a problem!
How much HP you running?
Old 03-22-2005, 03:28 PM
Redlinez's Avatar
I would only buy GM bearings and races period. I bought a Ratech kit and it's garbage IMO> Spend the extra money and get all the GM parts you can. I did pinion nut, crush sleeve, pinion bearings, carrier bearings and shims. The solid spacer is a good way to go from what everyone here has said.
Old 03-22-2005, 04:47 PM
BADSZ28's Avatar
I have motive gears and a Richmond install kit. Shouldn't the solid spacer come with the kit? What would they use in place of the solid spacer?
I too am building my 10-bolt. I already have axles, a cover, LCA brackets and welded the tubes. I am painting it now and the gears will be going in when the paint dries.
Old 03-22-2005, 04:50 PM
BADSZ28's Avatar
What is up with your cover? Looks like you are ready for paint.
Old 03-22-2005, 05:02 PM
ace68's Avatar
I'm polishing it that's the 400 grit next is a buffing wheel. who says you can't polish a terd
Old 03-22-2005, 05:11 PM
BADSZ28's Avatar
That will look nice. Not worth the time in my opinion, but hey some would say that me painting my rear is not worth it. Took forever to get all that rust off. Funny thing is I never drive in the snow, salt or rain (seldom). Should dress up the under carage though.
Old 03-22-2005, 05:24 PM
freakynipples69's Avatar
How neccessary is a Solid pinion spacer? I have the Motive master bearing install kit, shouldn't it come with it?
Old 03-22-2005, 10:08 PM
BADSZ28's Avatar
"How neccessary is a Solid pinion spacer? I have the Motive master bearing install kit, shouldn't it come with it?"
Is that the $100 kit or the $40 kit? I would really like to know this too.
