Patriot heads
Originally Posted by 1998TA__1991RS
i was looking at the stage 2's for 97-98's and was wondering what kind of gains i would see?? i have a ls6intake, tr224 cam, Lt's and boltons
Originally Posted by zamboxl
look to gain about 40 horses, maibe 30 on the low end, but most likely about 40 with what you got.
don't go with the 6.0 heads well actally i din't know PP had 6.0 heads, well anyways 6.0 heads will lower your cr and you'll loose power unless you planing on doing fi i dont recomend it. As far as the stage 3 heads you'll probably make a little more power but you also gotta know that with bigger ports come lower velocity meaning what you can only go so big with the stock cubes. You will make more power on the stage 3 heads, but where they'll really shine is if you go for bigger cubes like a 383 or a 402, or 427 strokers, or if you do Fi on you stock cubes. if not better just go with their stage 2 heads with the 59 cc conbustion chamber, this will bring your CR up to about 11.1 then just hook up a 100 shot of nitrous cause nitrous loves the high CR and 500 plus rwhp here you come actually 550 plus would be very doable.
i actually have nitrous on it but its not hooked up and ive never run it, i thought these heads would be good for a DD without having to spend too much money on them right now, when i build my motor bigger in the future ill prob go with some big and nice afr's or somthing of the like
what about the 67cc's im looking at the ones that are $995 in summit
i dont know if i will spray it though, if i do it will only be about 50-75hp shot, is about 1000$ about the right price for them or could i get them cheaper
edit heads ussually run for more than a $1000 but like i said if your patien you will get a good deal.
