quick oil pump question.
Good to hear, do you guys think i should change it when i do my cam swap or just keep it in there. It has 40,000 on it. I did a search and got so many mixed opinions on the subject.
Pump
There is no such thing as an LS6 pump. The new # is 12586665 and there is only 1 pump listed for the LS1/LS6. This was as of yesterday when my new arrived.
JIM
JIM
Has anyone taken these apart to see whats the difference between these two pumps? Did they open up the Cylinder bore a little or decrease the piston's OD? I'd like to measure both cylinder and pistons diameters from an p7-99 old style and the 01-02 new style. Are the springs the same?
David
David
JIM
JIM
Originally Posted by cyphur_traq
you're right, and wrong. its not so much that its an "LS6" pump, so much as they first came on the ls6 motors and 2001+ f and y body ls1's. it was a design shift that they have implemented across the board, and now they should ONLY be selling/shipping the new design, so if you buy the new pump you should be ok. thats why some people who run the part #'s on their "ported ls6 oil pumps" come up w/2001+ corvette part numbers.
That sounds right except I thought it was only 98 that had the old pump style.
