Fueling & Injection - no fuel to the passenger bank
obZidian
03-22-2005, 11:48 PM
hey, just like it says, my brother is having some trouble with the passenger bank (all cylinders) are not burning. The spark seems good, Cylinder pressure are grreat, even arcoss the board, the plugs arent soaked in fuel; so we have pinned it to no fuel. Wat are somethings that we should check for?
I've heard that there are two fuses that control the injestors, is that true for ls1'z?
Any help would be great ya'll
thanks
Angel
72ChevelleConv.LS1
03-23-2005, 06:10 AM
The pink wires to the injectors are the 12V hot ones (always on). the key needs to be on to check them. If no 12V then a fuse is bad. The other wire on each injector, is the one that fires the injector from the computer.
obZidian
03-23-2005, 09:53 AM
where would the fuse be located? inside by the driver of in the engine bay? I was told be the driver but im not sure...will check it out...
thanks, any other suggestions?
72ChevelleConv.LS1
03-23-2005, 04:03 PM
sorry I dont know I dont have a F-body
obZidian
03-24-2005, 09:40 AM
I just went over to his house and checked his fuses, visually, and they looked fine. When we get sometime, we'll get a tester and see wat kind of voltage he has running.
is there anything else that might cause this? It seems like its just not getting fuel to the passenger side bank..all of the cylinders!!
thanks
Chris@AP-Engineering
03-24-2005, 10:42 AM
thanks
This isn't your car is it??? Hopefully not!!
obZidian
03-25-2005, 12:13 AM
oh no chris, my car is running just fine!! thank you for the torque monster!!!!!!!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
