What's the biggest cam with a stock converter?
Searced....sucks. What is the biggest cam I can go with a stock converter. I am not buying an aftermarket converter because I drive this car every day 500-700 miles a week. Aftermarket converters just dont have the reliability. I will slowly do all the bolt ons. Just seeign how big I could go. Is the 02 Z06 cam to big? Car 99 Z with 3:15's
Thanks, Andy
Thanks, Andy
LS1 Tech Administrator
The biggest concern when running a stock converter is the idle speed. Stock rpm in drive is 550. Once you get above 700 rpm, the car wants to pull against the brakes. That means you'll be limited to cams with small degrees of overlap like the Z06 cam, the LPE GT2-3 cam (207/220 118.5LSA), Vinci 210/218 cam, or the TR Old Man Cam (214/220 115LSA). If you get a factory converter with higher stall like a Trailblazer converter, you'll be able to run a bigger cam and still keep your reliability high. The Trailblazer converter stalls about 800 more rpm than stock. It's what I would run if I were in your shoes.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by snketr
Any idea where to get a Trailblazer converter? I don't want the Z06 cam so to speak I was just trying to get a ballpark figure of what will work.
I used to drive (and race on the weekends) my Vig3200 equipped Camaro SS well over 1100 miles a week for two years, hell I even took it to Texas from Ca (over 3000 miles one way!) to visit relatives twice. If that is not reliable, then I don't know what is.
Ok, just ordered my TB convertor at the shop from the dealer $234 +a core. Now what cam can I get? What is the biggest dur I should go? Lift, and C/L?
Thanks, Andy
Thanks, Andy
Thanks, Andy
Thanks, Andy
The year doesn't matter as long as you get the converter from the 4.2L inline 6. Don't get the 5.3L V-8 converter, LOL.
__________________
I was considering using either CompCams 206/212 112lsa or their 212/218 115lsa high lift cams for my stock converter/no tune setup. I chose the 206 cam because of the tighter lsa. I then used 1.85 rockers to get the higher lift. This little combo makes a very noticeable improvement from off idle up to 6000+. The power improvement is across the board. HTHs
