LS1 , Cubic inch question
hello . i am building a 69 camaro convertible. i plan to use either a magnacharger or a turbo. i would like to have at least 600hp . i do not however want a stock ls1 displacement . i am wondering what to use . could anyone give me some insight on a combination to use with this . heads , cam , rotating assembly, etc...
please give me some advice from experience , thanks
Originally Posted by 777
if you want to use an ls1 block i would go 383 (same bore, stroker crank) if you want an ls2 (aluminum) or lq9 (iron) you can do a 402-408...you could also resleeve the ls1 for a 427 big$$$ or get a c5r block real big $$$ like 6,000 for block alone
All very viable options, but for 600hp a simple 402 iron block will do the trick, with pretty much any F/I you put on it.
SN95 Director
sell the ls1 and build up an ls2 402. by the time you do all the machine work, purchase the rotating assembly, ect the price difference between the 383 and 402 is minimalistic.
are you talking flywheel or rear wheel HP? with the proper h/c setup on the 402 you can have over 500rwhp easy.
