fuel pressure and jetting question
i have the gm universal NX kit on my car. i also have a holley fuel pressure regulator coming off of the stock fuel rail then into a fps switch.
My question is- I have the fuel pressure set at 6 psi. and i have the 35 n20 jet, and 18 nitrous jet in. Is this correct for a 50shot?? Is my fuel pressure correct. What about when i go 100 - 150 shot.. what should my fuel pressure
be at::::
Thanks alot
p.s. i have a stock fuel pump and 370 RWHP w/out n2o.
be at::::
Thanks alot
be at::::
Thanks alot
be at::::
Thanks alot
so the regulator is doing nothing. Will i make more power with out the regulator???
Wont 58psi cause it to run a little rich????
Im new to this. i am used to carbs.
