Advise: Just had car tunned, Look at my #'s tell me what you think.
Originally Posted by Black02SS
Can you post a pic of your graph? If your afr was just below 14, then it IMO, is too lean and needs to be richened up. Normally I have seen optimal results with a little richer down low up to peak tq and then lean it out up top. 12.7-13.1
but it sounds like they put the wideband after a CAT or something.
If that's the case, then the AFR graph is worthless.
Also they ran the tester to the tailpipe.
Originally Posted by 1 BLOWN V8
If someone could host it that would be great. I treid but it said the file was to big.
