Anyone using the COMP 941 valvesprings?
Old 03-24-2005, 08:16 AM
DragLS1's Avatar
Question Anyone using the COMP 941 valvesprings?
I would like to use the comp 941's. Does anyone else use these springs? The cam that I am going to use has .612" lift which puts me @ .010 away from coil bind at full lift at an installed height of 1.750". What retainers fit these springs? Do they fit into the stock spring cups at an O.D. of 1.260?
Thanks
Old 03-24-2005, 09:08 AM
cyphur's Avatar
why not run 921's. they're rated to .650.
Old 03-24-2005, 09:37 AM
DragLS1's Avatar
Wink
Well, the only reason that I don't want to use the 921's is because they cost right at 400.00. I think I found a set of crane springs that will work that are rated at .650" lift, but have slightly lower seat and open pressures. No problem though, I can shim them .030 and still be .010" away from the net rated max lift that crane recommends. And they are only 150.00.
Old 03-24-2005, 10:42 AM
Unaffliated Racing's Avatar
It would probably be even better to run the 918 springs.
