Bigger injectors
You're probably still ok on the stock '99 26# injectors. Once you get up around 400rwhp they'll probably be maxed out. You'll only loose HP if you're injectors can't keep up and supply enough fuel. Couldn't hurt to add larger injectors now though if you anticipate additional mods in the near future.
