best way to bleed air outa the system
Old 03-25-2005, 07:04 PM
SSPerformance's Avatar
Default best way to bleed air outa the system
just did a heads and cam swap what is the best way to bleed the air outa the system my car is a 98
Old 03-25-2005, 07:12 PM
blue by you's Avatar
If you have a non-spill funnel, slap it on the radiator neck, pour in your coolant and start it. Just keep an eye on it. You shouldn't have a problem with an air lock in it as long as you fill it before you start it.
Old 03-25-2005, 07:50 PM
well ur wrong is already has alot of air in the system. anyone else
Old 03-25-2005, 10:57 PM
Beast96Z's Avatar
I always fill the block through the thermostat hole first, then hook all that up and fill the radiator. Then crank and let it bubble out. A small hole drilled in the thermostat helps with getting air out also.
Old 03-26-2005, 07:53 AM
i read to unhook the hose that runs to the metal lines under the intake and let it buble out
Old 03-26-2005, 08:28 AM
NHRATA01's Avatar
I started by leaving the Coolant temp sensor and freeze plug in each side head off, and I started fililng the radiator until it leaked out from both openings. Then I plugged both of those and filled it with the coolant line from the x-over pipe to the TB open, until it leaked from there. Buttoned that up, topped off the radiator, then started the car with the raidaor cap off, and let the Tstat open while watching the level in the radiator rise and fall, and added coolant as needed. Worked fine for me.
Old 03-26-2005, 08:37 AM
Mirek's Avatar
I re-filled the radiator, started mine then drove it around, then the temp popped up to 250ish so I shut it down and opened the radiator cap, it gurgled and bubbled for about 30 seconds then I filled it again, it has been good to go since then (two days ago).
Old 03-26-2005, 10:00 AM
i used the ls1howto.com way thanks for the help guys
Old 03-26-2005, 04:57 PM
Bad N Black's Avatar
Mac tools sells this thing that hooks up to shop air and evacs the rad and block 4 about $60.00 to $ 80.00. It's pretty cool it puts vacume inside the radiator and the you stick a hose in a bucket of antifreeze and flip a switch and puff no air pockets.
Old 03-27-2005, 11:18 AM
Tritonium's Avatar
been searching the web for this, any idea where it may be? thanks
Old 03-27-2005, 12:06 PM
i used my method i used a presure tester and took the hose of the coolant pipe that goes head to head gave it a few pump and kept refing the radiator and kept doing it till push water out the top
