32 lb injectors
Would going from 28 to 32 lb injectors make less power, make it run bad or just be a waste of money? I've seen calculators to find out what size I need but I don't know my fuel pressure.
LS1TECH Sponsor
if you do replace them you will need to get retuned regardless if there not need then the duty cycle will just get turned down . to big of an injector can be bad if it cant be set any lower . injectors dont make any power by themselves however you do need to have the right size for the power level and setup . get the car autotaped and see where you are now and go from there . every vehicle can be different
