port match 90mm LSX intake for 205 AFR heads
Old 03-26-2005, 10:32 PM
Abdullah's Avatar
Default port match 90mm LSX intake for 205 AFR heads
is there any binfit of port matching 90mm LSX intake with hand ported 205 AFR heads? how much hp gain i will get? thanks.
Old 03-26-2005, 10:34 PM
Abdullah's Avatar
Old 03-27-2005, 12:41 AM
Nate_Taufer's Avatar
I can't give you an exact number but every little bit helps.
Nate
Old 03-27-2005, 11:24 PM
Abdullah's Avatar
any one else can give a more specific answer? thanks.
Old 03-28-2005, 12:38 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
When I ported my FAST 90 I did a little more than a basic "port match"....I reworked the runners a few inches back and reshaped some of the exit walls....took the "tilt" out of the exits and addressed the area by the inector bosses etc. Ended up seeing an additional 6-7 CFM at the cylinder head when flowed on the bench testing a box stock FAST against the one I reworked. My best guess on a street application (11 to 1 CR, 220-230's camshaft) would be at least a one to one gain in HP as well (6-7 HP). When I hit the dyno with the 62cc 225's in a month or two I will be doing a back to back test to evaluate the actual gains on an engine dyno. (I'm thinking no less than 5 HP and no more than 10....we shall see). It could be more on a larger displacement engine more starved for airflow.
Tony M.
Old 03-28-2005, 07:28 AM
SlickVert's Avatar
Tony,
Thanks for the good info.
Do you think that there would be any benefit in removing the lip that is one inch in behind the TB opening and blending it in with a radius.
File Type: doc
Old 03-28-2005, 05:44 PM
WILWAXU's Avatar
How far off are they?
Old 03-28-2005, 05:49 PM
LSUxBlake's Avatar
I'd definitely port match them. A person who knows what they are doing will do more than just match the ports, such as radiusing the entry on the top of the port. Here's a pic of my port, done by Futral Motorsports.
Old 03-28-2005, 07:59 PM
SlickVert's Avatar
Ttt Tt
Old 03-28-2005, 08:44 PM
LeMansBlue04's Avatar
Originally Posted by dame
How long did it take you, and would you be willing to do it for us also (for a fee of course)
Yikes! My A4 horsepower secrets are about to be uncovered!
Old 03-28-2005, 09:05 PM
LSUxBlake's Avatar
I posted this in the other thread asking this I believe, so here it is again. This is my port, done by Allan Futral.
Old 03-28-2005, 10:04 PM
Flow Wizard
What.....no pics??
(I busted my butt on that intake!....lol)
Old 03-28-2005, 10:49 PM
DrkPhx's Avatar
Originally Posted by SlickVert
Tony,
I think it would be more beneficial to smooth out the lower part of the TB ring to match it to the black, lower part of the intake.
Old 03-29-2005, 03:23 AM
SPIV's Avatar
Tony M.
Hi Tony,
Does AFR offer a ported FAST manifold available for sale or do I have to get my cylinder head guy to do it?
Cheers
Old 03-29-2005, 10:52 PM
Originally Posted by SPIV
Hi Tony,
Cheers
Ya need to talk with Tony, he can sell you one and he can port it. How do I know? Well.....
A few months ago I duplicated Tony's project Corvette, only I did it with an automatic. I decided that if I was gonna do this I was going whole hog. I believe that engines are a package and Tony had developed a package. So I did it all.
Now, almost anyone you talk to will tell you that the FAST intake is not really practical for a 346 CI motor and that it really offers no significant gains until you put it in a stroker motor. In fact most people seem to believe that a FAST will actually hurt low end torque on a 346CI motor.
Well all I can say is
I can see why they would assume that. I have seen testing results done on a FAST vs LS6 vs LS2. However, the engine they tested with was a crate motor with headers and a less than impressive cam. It wasn't a PACKAGE and the intake wasn't ported.
But heck, even my tuner thought I had lost my mind when I put a FAST with a 90mm Nick Williams on my car. When they found out I had paid Tony to port it I suspect they were laughing at me behind my back. But not anymore, not after the first dyno pull.
My car has the AFR 205 heads on it and it has the AFR cam 224/228 with .581 and .588 lift on a 114+1. Guys, I'm making a little over 440 at the wheels and the torque is over 400. Those are corrected numbers. When the temprature is around 65 outside we have seen over 452 uncorrected. That's with an automatic that idles well at 765 RPM using 3.73 gears and a converter with a stall of only 2800 and a mere STR of 1.9 to 1.
Ok, some people don't trust the dyno, they want track numbers. How about 11.64 @ 120.3 MPH on drag radials? And the car weighs 3400 lbs no less. This is a Coupe not the lighter ZO6. When I get my Yank PY3600C5 converter in it I could be at 11.30 or 11.40, right now my 60 foot times are around 1.850. The new converter will change that. Right now it has so much torque at the line that I can't hold it past about 1800 RPM. It overcomes the brakes.
So, get yourself some good heads such as the AFR,s. Get some good headers and a good set of gears. Make the changes you need to make to get power. Then when you think you've done everything you can short of NO2, a blower or a stroker, call Tony. Get a ported FAST, a 90mm throttle body and some larger injectors. trust me... there is more power there.
But don't tell the Vette guys over on Corvette Forum, Ok. They still think the FAST is overkill on 346CI motor. I never tell them mine is ported so let's just keep this our little secret so I can keep beating my fellow Vette owners at the track.
Old 03-30-2005, 09:01 AM
2c5s's Avatar
[QUOTE=
[/QUOTE]
No offense, but my 99 c5 a4 3.42 346 stage 2 ls1 head (291@.600) TPIS LT's stock cats 224/569-114 ran 11.70 @118 all day long. Dynoed 393 rwhp on Morgans crap tune and bogus dyno. I would expect your mph to higher.....
Old 03-30-2005, 08:08 PM
Don't worry, no offense taken,
What converter and tires are you running?
Old 03-30-2005, 08:31 PM
2c5s's Avatar
SY3500 on e.t. streets. high 1.7 60 ft.
Old 03-30-2005, 09:10 PM
Mirek's Avatar
Thats pretty fast. Which drag radial and did it fit on the stock rim?
I 'might' have considered a ported FAST had I went with the 225's and a daddy cam....I have not dyno'd mine but I hope for 400+ torque (I know hope in one hand.....) Remember, Tony's is THE AFR car. The one in the mag, the net, etc...he had a very good reason for eaking those last few high RPM horses. Nice set up anyway.
Old 04-20-2005, 01:36 AM
PurdueWS6's Avatar
Ok, got a question, what kind of porting tool can I use to port the intake manifold to match it to the heads??
Quick Reply: port match 90mm LSX intake for 205 AFR heads
