Drag Racing Tech
Is anyone running a Mark Williams Ford thru Bolt Aluminum Case??
Old 03-26-2005, 10:40 PM
squinn's Avatar
Default Is anyone running a Mark Williams Ford thru Bolt Aluminum Case??
Are you running a moser housing, how did you get the long TA bolts to clear the thru case bolt heads? Or can I just space the TA support out a 1/4" or so?
Why do I always have to be the first to try new things.
Old 03-26-2005, 11:11 PM
LS1Tech Sponsor
MADMAN's Avatar
Good luck Steve. I had one for my car and I had to space the mount out to clear it. I didnt like that setup so I sold the center section.
__________________
www.madmanandcoracing.com
225-343-9029
Old 03-28-2005, 05:38 AM
squinn's Avatar
Brian what did you not like about this setup, just the fact you had to space it out?
Old 03-28-2005, 06:23 AM
LS1Tech Sponsor
MADMAN's Avatar
I was worried about the spacers. I probably should have cut the mounts off the housing and made new ones.
__________________
225-343-9029
