TSP Dual mounting question
Old 03-27-2005, 09:45 PM
MachoCamacho's Avatar
Default TSP Dual mounting question
Where am I suppose to mount the muffler mounts? on the floor pan or what?
Old 03-27-2005, 09:48 PM
code4's Avatar
I mounted mine on the floor pan directly behind the lower rear seats. Maybe you can see them in this pic.
Old 03-28-2005, 12:01 AM
psykoTA's Avatar
There a giant pumpkin in the way
Old 03-28-2005, 12:15 AM
jj_z28's Avatar
This will kind of give you an idea. Check out the 3rd pic. I welded my mounts the the floor plan, but most bolt them.
https://ls1tech.com/forums/generation-iii-external-engine/296487-tsp-true-duals-w-eibach-sportlines-pics.html
I posted this earlier.
Old 03-28-2005, 01:15 AM
Y2K SS's Avatar
Depends.... are you gonna dump before the rear end or not?? I ran my pipes to the rear and bolted them on the floor pan as the pan goes up behind the seat. I used thick rubber gaskets to keep down the noise and vibration.
