Automatic Transmission - got a big problem with a vacuum system
Mexican
03-28-2005, 10:24 AM
I just got the trans back thursday, and we put it in friday night along with my headers and true duals. I drove it all day saturday and it was shifting fine. as i was starting to take off at about 1/4 of throtle my trans made this lound PoP and reved up. I pulled over and my car would not go into reverse or park just 1,2,d,od, and n. the trans will not go into gear in drive it would just rap out. I would have to shift it manualy to drive, could this mean that my sprag is broke ??? and also on my way home my car started to smoke so i pulled over and i had trans fluid in my vacuum line the only thing i could think of is that the line came loose in side the trans pan. does any one know what could be wrong? I have a vig2800 and a shift kit. things shouldnt fuck up while im driving around. :cry:
WeeWolf
03-28-2005, 09:30 PM
you might pull the pan and make sure the line is connected for the vacuum line you might even find the park rod came loose causing no park or reverse.
