How do you know if your 02's are shot?
Old 03-29-2005, 05:03 PM
jimmy 2 Times's Avatar
Default How do you know if your 02's are shot?
how do you know if they are shot? I was driving around with out a tune for a while (running rich) then after it was tuned. and now i am running open headers (until i finish the true duals) my question is, how do you know they are shot? i havent set off any codes yet but i dont want them to go when i cant replace them
thanks for the help
jimmy
Old 03-30-2005, 08:14 AM
no one knows??
Old 03-30-2005, 08:44 AM
It's not mine! woo hoo!
demonspeed's Avatar
How do you change your tranny fluid?
j/k.
Old 03-30-2005, 09:09 AM
j/k.
smart ***, i wanted to know the "easiest way"
how is your POS running?
Old 03-30-2005, 09:31 AM
REDLV SS's Avatar
With Autotap or the like you can take a drive and monitor all your O2 readings to see if the are were they should be.
Old 03-30-2005, 09:51 AM
P Mack's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/185715-errors-133-153-a.html
They could be shot without looking this bad though.
Old 03-30-2005, 04:00 PM
demonspeed's Avatar
Blew the Torsen out a month ago. I threw an Eaton in it for the time being. Other than that, I can't complain for the amount of abuse it sees.
