Tick after change to synthetic normal?
Old 03-30-2005, 08:01 AM
rufretic's Avatar
Default Tick after change to synthetic normal?
I've used regular oil for 27,000 miles and just changed my cam. I used 30 valvaline right after I swaped cams because it was cheap and I wanted to change to synthetic shortly after the new cam. I noticed very little valvetrain noise. I was kind of surprized after reading all the threads about engine noise after a cam. I switched to 10 w30 mobil 1 synthetic about 70 miles after the cam swap. Now I have a lot more valvetrain noise and a slight tick. The only thing I changed was the oil. Now I'm wondering if I should go back. Is it normal for synthetic oil to make more noise? TIA.
Old 03-30-2005, 08:13 AM
AKRA's Avatar
You will get more noise with synthetic oils. Also those taller springs will make it sound like a sewing machine at a idle.
Synthetics might make it last longer but it leaks easyer and makes more noise. I personnally have no problems with regular oil. you just need to make sure you change it every 2500 miles.
Good luck.
Al
Old 03-30-2005, 09:17 AM
rufretic's Avatar
Ok thanks. So is it a big deal to switch back to regular oil? Some people say you shouldn't switch back, I don't understand why. I don't mind changing oil often, I just want it to run good and quiet.
Old 03-30-2005, 12:49 PM
TigerFan187's Avatar
I run synthetic and when I swapped the 4.8 with a LS1(w/new valvetrain) it got a whole lot louder and actually lately its gotten a little louder but Ive been told its normal and/or its lifter noise-blah blah blah. In all reality I cant stand it!LOL! Hell with all the probelms I had with the 4.8 dying and then 2 days after the LS1 swap getting psiton damage any knocking/ticking made me nervous!
Old 03-31-2005, 06:28 AM
vettenuts's Avatar
I think the problem is you went from a 30W to essentially a 20W. Mobil-1 is about 10 Cst at temperature which is very low in the 30W range (<9.3 is 20W). I would switch to a synthetic that has greater viscosity at temperature like German Castrol 0W-30 or Amsoil 5W-30. The Mobil-1 oils are very thin.
Old 03-31-2005, 07:04 AM
rufretic's Avatar
Thanks for your advice, I think I'm going to try that. I've read a lot of good things about the german w0-30. I just hope I can find it.
Old 04-01-2005, 04:32 PM
slow3hoe2's Avatar
let us know what you think when you change it to GC. I ran mobil 1 5w-30 all last season...and now i have pepboys proline 5w-30 and its a lot quieter. I saw the GC in autozone yesterday, but was afraid to spend $35 and have the valve train get louder, and then have to switch it back. thanks
