Removing shortblock
Removing shortblock
Why can't I yank the shortblock out? All the bolts holding it to the tranny have been removed. I can't get the passenger side to seperate. The drivers side seperates fine. I removed 8 bolts from the tranny too. I am trying to pull it from the top cause I really don't want to drop the K-member and pull it from the bottom. Is there something I am missing? The motor mount bolts have been removed to as well as the oil pan bolts. Just so no one thinks I forgot these bolts.
I can't even get a pry bar in there! There are no wires or anything it is just being stubborn. I was just thinking maybe there is something I missed or a technique to getting it out. I sure hope I can get this thing out. It is a 2000 and the motor has never been removed.
ya what he said, you need to seperate the trans from the block if you havent. the dowls the line the two up will seize into the trans case. I did a clutch swap/trans rebuild about a month ago and had to pry the **** out of the bellhousing to get it off. good luck.
Yeah the tranny is still mounted. I was hoping to pull the motor with out the tranny. I see the dowels but didn't know I would need to pull the tranny too. So either way I pull the engine (top or bottom) I should remove the tranny too?
Yes, take the tranny out from the bottom. I just did a H/C swap, along with a new TC, I had more trouble taking the tranny out than anything else, I had to pry on it like no other. I kind of welds itself in place with the dowel pins. I pulled my engine most of the way out during my swap, because the oil dipstick tube broke off in the oil pan so i had to take the pan off to get it out. With the engine disassembled it should come out the top no problem. If and when I do it again i will take it out the bottom and put a lightweight K member and new a arms. Good luck
Yaal are retarted if you are going to take the tranny out of the bottom.
I bet what is holdoing motor in is the motor mounts. Why dont u just unbolt them from the Kmember.
Did you take the DS out and the tranny cross member and the wiring harness of the tranny.
Also you need to drop the *** end of the tranny so the motor can come straight up.
The enigen hoist will be almost maxed out when you get the motor out of the car.
Good luck.
Good luck.
Just pulled mine out the other day. It was easier to pull the motor and tranny out together through the top. Put the front of the car on jackstands about 2 feet off the ground. Make sure everything is unbolted and all wires unpluged. There is a ton of sensors in there. Then you have to tilt the motor up a pretty good ways. Almost so the tranny is touching the floor. A little lift and tilt here and there and it will come out. Not as hard as i thought it would be.
