Can AN aluminium fittings be used on steel line?
Can you use Hard tube AN fittings on steel fuel line? It says for use on aluminium line everywhere, but doesnt say if it can or can not be used on standard factory steel lines.
Anyone ever done so without leaks?
Originally Posted by GTS346
Thanks hawk, also do u know if you can put 90 degree bends in aluminium tube when making fuel lines or does it fracture the line?
