Did your 10 bolt do this
I have searched many of the other threads and couldn't find a diffinitive answer to my questions so here it goes.
I have a '01 WS6, A4, 3.23. I was crusing down the interstate @ 80 mph when I heard the dreaded rearend whine.
I let of the gas and decelerate, still there. Change speeds, still there. It does it at all speeds wheather I'm accelerating or decelerating but no clunking or banging.
So, I pulled of the cover and inspected what I could no broken teeth but I found some very small metal shavings on the magnet.
Anyone know what it could be? Can I fix it myself? If so what kind of special tools would I need? How long can I drive it like it is? I plan on going to a 9" or 12 bolt in the future, so I would like to keep from spending alot of money on the POS 10 bolt.
TIA.
TIA.
14 Second Truck Club
If it is there at all speeds I owuld suspect a bearing failure. It should change pitch as the speed goes up. Most gear noise will be either coast or drive(rarely both), or at a certain speed. If the gears look good with no sharp edges, chipped teeth or pitting, I would check the bearings next. Grab the pinoin yoke and try moving it around. It should rotate obviously, but not have movement in any other direction- up and down or side to side.
Thanks. Is it possible to change the bearings myself? I went to Advance Auto Parts and they sell a bearing and seal replacement kit for 99 bucks. it's made by southern gear.
Black00TA, I'm LMAO at the photo in your sig.
yeah, gear whine will change pitch with rotational speed and will tend to be louder on either accel or decel, but not both. Bad bearings will be less of a whine and more of a just a light roar or grinding sound and will stay pretty constant. I have gear whine in two of my cars. and I've had a few bearings go bad over the years. Definitely a different sound.
