rev limiter hp tuners
did a search and didnt find what i need. what should i set my rev limiter to? i have a 224 cam on a 111lsa, patriot gold duals, tit retainers, hardnd pushrods, ls6 intake, long tubes, m6. where do you think my peak power range will be?
i'd leave it around 6600 shutoff, 6400-6500 shifts... get it on a dyno and you can see if it'd be valuable to shift higher
w/that setup you're probably good for 7k+ RPM , but no sense spinning that high if you don't need to
224 111lsa dyno sheet
just looking at this what you guys think i should shift and set my rev limiter to? i have a raptor shift light on its way so i will want to set it to this number. i know i need to dyno it in my car but im still tuning it.
I would set it at 6800, shift at 6600 for dropping the revs back to 4800. Thats an awesome power spread at the top there and you should take advantage of it as much as possible.
Keep us posted.
Keep us posted.
i set it to 6600 and until i get a shift light i wont know when im shifting. according to my logs i am currently shifting at 5800, lol my tach is waaay off. should have my shift light next wednesday, well see. thanks a bunch.
