12 bolt question
12 bolt question
if i have abs option on my car now, and i dont oreder it on my 12 bolt, would i have to get a kit for any lines or anything or the abs just not work?? the abs inop light is on anyways, and i dont really car about it... and would a 30 spline be good for a 4k+ transbrake and about 500hp??
and what are the c-clips?? and do you really need the t/a cover, i got one with my 10 bolt but didnt think it helped to much... does it make that big of a diff?? thanks, trying to get everything together to order my 12 bolt.. thanks, dwayne
I dont think the TA cover really helps in. Just my 2c I have a Moser 12-bolt with 33 splines and 4.11 gears I dont know all that much about the transbrake and the 500 hp my car is near about stock...I just called and let my mechanic talk to the guys at Moser and they set me right up. I'm sure someone knows a bit more than me just thought id say this. But I love the new rear end set up. Alot of fun and alot of pull. enjoy
yeah, the guys that built my cam said it was going to be made for 4.30 gears with all the specs i gave them... and the goals of it... i dont think the t/a does either, i might just get a 12 bolt and not the abs or the ta with the 30 spline..
and doesnt moser give you 33 spline if you break the 30's and if you break the 33's they give you 35's and then 40's??? thats just what i was told...???
