how to get new abs rings for the axel?
I have called all the local dealers and some of the part stores around here no one sell the rings without the axel.
Slowhawk said I can get the rings seperate but I have not found where to get them yet can anyone help a sucka out
LS1Tech Sponsor
I heard that when GM installs them they freeze the axle shaft and heat up the rings. Good luck, I have tried putting them in my press and I break them everytime.
We have new GM ABS rings in stock. $69 pair.
Thanks
Moser axels WJ. I left the stock rings on the stock axels so if I need to I can just change the axel with no effect on the abs or traction controll.
GM Muscle how do you make one? I put some hot water in a can then droped in the ice but it just smoked.
Get some water bottles or soda bottles. Basicly anything with a screw on cap. Fill them a 1/3-1/2 with water and jamb a bunch or dry ice into the bottle, screw the cap on, huck it away from you and give it alittle time. They are ******* loud when they blow, I had threw 3 2 liter ones in the empty dumpster at work and the cops showed up not long after. Luckily they all know us so they really didn't care.
BTW: I'm putting in my Mosers today. For some reason mine came with a dual bolt pattern, not that I'll ever need it. The backing plates on the end of the housing don't have to come off to slide the axles out, right?
**** that's funny.
right they come out once you take off the rotor and the c-clip.
I ordred mine irect from Moser and told them i wanted the abs and stock patton and their studs, cuz they didn't have arp I bought some but I think I will use them in the front.
