got 11's 6 hours after the car was cranked with the new engine.
For 3 runs I had a problem with the Pro 5.0, that b*tch hates 4th gear. 4th pass I got a 11.49 @ 120. I'll practice a little more and give it another try. Mods in sig. I either need a new shifter, or practice with it.
Originally Posted by Caveman
Well that car used to be much quicker(10.17 I think)with the poorly built turbo setup. It might have run better if you had cleaned up the previous setup
Originally Posted by waltsfastz
What did you do to the motor? Fresh? Surely you didnt give it some breakin time on a new motor before hitting the track?
Originally Posted by NBMSS
So I see your happy with the motor. Hopefully mine will be running by summer. Glad to see what the motor was capable of with a good suspension and a good driver.
its amazing how much better your times are when you use 4 gears instead of 3. just messing with ya. car runs good, and has a tenth or two left in it with a wide ban tune and some suspension tuning. i don't think you guys understand what we went through to get that thing running friday, much less to the track. suspension was setup the same way we put it on the car, computer was flashed at 4:45, over the axle pipe was made at 5:30, drove it home, then to the track. only "track prep" that was done was airing done the tires. even left the cut out on. give it a few months... it won't be in the 11's for very long.
TT-TECH Veteran
