engine dies on right hand turns
Old 04-02-2005, 02:21 PM
L P C's Avatar
Default engine dies on right hand turns
wheneve i make a right hand turn the engine stutters for a sec and cuts off. speed doesnt matter and does it with clutch in and out. when it stalls the check engine, check guages, skip shift, low oil light comes on. the oil level is fine, and it has the skip shift resistor in it
it is a 98 ls1 with a t56
Old 04-02-2005, 04:24 PM
01ArcticSS's Avatar
Just a guess, but if the turn is the ONLY way you can get it to die, then you may be pinching a wire with the steering parts and shorting it out.
But it's just a guess.
Old 04-02-2005, 08:40 PM
cgworth's Avatar
Sounds like a bad ground somewhere. run a temporary ground from the ground lug on the pass fender and ground the pcm with an aligator clip or something and see if that fixes it . if so then you have a bad ground somewhere
Old 04-02-2005, 10:01 PM
01ArcticSS's Avatar
Originally Posted by cgworth
Dont Let Off Until You Smell **** and Hear Glass Breakin
Sorry, but I LOVE that sig!!
Old 04-03-2005, 11:52 AM
jmilz28's Avatar
Could "possibly" be a fuel sending problem too.
Old 04-03-2005, 12:48 PM
Gen3Benz's Avatar
yeah, maybe the fuel tank baffle is messed up.
