engine dies on right hand turns
wheneve i make a right hand turn the engine stutters for a sec and cuts off. speed doesnt matter and does it with clutch in and out. when it stalls the check engine, check guages, skip shift, low oil light comes on. the oil level is fine, and it has the skip shift resistor in it
it is a 98 ls1 with a t56
How much fuel is in the tank when this happens? How much fuel presure do you have at the injector rail? You may have a weak fuel pump. Or you could have a cable that hits someting (or something hits it) and shorts out on right hand turns. Also possible a loose ground wire.
