New LS1 Owners - Newbie Tech - engine cleaning
camar0guy
04-02-2005, 10:23 PM
ok so im bout to clean my engine bay, as you can see its not in the best shape, i recently bought it and had no chance to clean it et
http://img.photobucket.com/albums/v230/CAMAR0GUY/ok1613.jpg
can someone cirlce what i need to cover up, or ptotect whle cleaning?
i know theres a thread on cleaning it but im not all that sure if ill get everyting, i just dont wanna mess up
thx
SmokingWS6
04-02-2005, 11:39 PM
The knock sensors are under the intake manifold and over time can mialfunction after repeated washing. I don't cover up any thing, i give everything medium pressure or so and wash it clean. Pretty much common sense, don't blast 100psi on the fuse boxes, pcm. but a little water won't hurt it. I was my engine bay about once a month.
nvrstsfd23
04-03-2005, 12:40 AM
yeah if ur carefull and don't use crazy water pressure u should be able to use soap and water, scrub the stubborn spots with a sponge or brush, hose off with medium pressure and be carefull around electric areas and such. Once done start the car and let the engine dry itself, and ur done.
DeepBlueZ
04-03-2005, 03:04 AM
I do mine by hand....bottle of simple green and a rag.
It takes a long time, but you can be mroe thorough and there's much less chance of screwing anything up.
takes me about an hour or so to get my engine compartment all nice and clean again.
98Z-6Speed
04-03-2005, 08:24 PM
Hose her down man, you won't hurt anything at all. No need for covering anything.
The old man
04-03-2005, 08:37 PM
Go to AutoZone and get a spray can of CD2 engine cleaner.Is like $3.99. Follow the directions and you will be very happy with the results!! :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
