track times with the Trex
Old 04-03-2005, 01:37 AM
LS6 SS's Avatar
Talking track times with the Trex
went out to the track today to make a few pass the best pass was a 6.81 with a 1.48 60" at 99.65mph i am happy with the time not bad at all but i know the car had a 6.7? in it but i could not get my 60" to go any lower since i have to busted shocks o well i guess i am going to have get the 2 busted shock fixed and then go back out there and try to get some good weather aswell. The car used to pull 1.46- 1.45 60" before with a bad tranny but that was with good shock so i guess once i get the new shocks we will see what she does
Old 04-03-2005, 12:31 PM
DanZ28's Avatar
What other mods do you have? Was that motor only or with N20?
Old 04-03-2005, 12:56 PM
LS6 SS's Avatar
the car is NA i have every bolt on even the 90 LSx intake with every suspension mod besides TQ arm and Sway bar i have a faster Time slip then that but i am trying to comfrim if it is correct since i red light on that run i am going to call the track today and talk to them about if so the car went faster then that on the last run of the night
Old 04-04-2005, 02:04 PM
PewterZ28's Avatar
A red light won't effect your ET. The timing starts when you leave, not when the light turns green. Your last time slip is probably legit.
Old 04-04-2005, 02:23 PM
BBQLS1's Avatar
How is the idle? Tuned or not?
Old 04-04-2005, 02:43 PM
erodrig2's Avatar
How is the t-rex on the street with your AC on? I have the TR230 but i want to go bigger.
Old 04-04-2005, 02:57 PM
DMcRacer's Avatar
He knows how the timimg system works. It was kind of a complicated situation.
Old 04-05-2005, 04:23 AM
LS6 SS's Avatar
very good not a problem at all but when it is cold out side i do have to let it warm up alittle then it is fine and yes it is tuned
Old 04-05-2005, 04:24 AM
LS6 SS's Avatar
i pulled the A/c off the car so i dont know but i dont think it will be a problem with the right tune
Old 04-05-2005, 04:25 AM
LS6 SS's Avatar
hey DMC i have some good new for u i will give u a call when i get up tom i just got home from work
Old 04-06-2005, 08:27 AM
BADSZ28's Avatar
Any Dyno numbers? What is your R/W? I am guessing auto?
Old 04-06-2005, 02:01 PM
LS6 SS's Avatar
here is al link to the dyno #
https://ls1tech.com/forums/dynamometer-results-comparisons/302013-trex-dyno.html
Old 04-06-2005, 03:49 PM
7 Second Club / STF Veteran
68maro's Avatar
trap seems a little low?
Quick Reply: track times with the Trex
