Exhaust looks good Ellis
Ellis thanks cut out looks much better should be able to grab second without the cutout hitting the pavement.
Pretty clever the solution you came up with to fix that. I'm also impressed that you were able to get the pipe apart without cutting it.
t just takes time and effort. That and I hate a chop/hack job of any kind so when ever I can I find a work around The cut out had taken a pretty bad beating. I cleaned it up a little so it would fit right.
Just got installing the new converter in the Vert. Did not get as much stall as I wanted but it did loosen up a bit. In the limited sun light we have the thing looks damn incredible. Another fine SG Detail job!
