Water Pump leaking
Water Pump leaking
I think my water pump is shot. When I got home yesterday it was leaking coolant. I got under the car but couldn't figure out where it's coming from. All the gaskets on the block and thermostat housing is dry. Is there a weep hole under this area I can't see ?
The car only has 35k miles on it, anyone else have this happen so soon?
How hard is it to replace ? Any recomendations on what pump to replace with ? Should I stick with a GM pump or
is it ok to use something from NAPA?
anyone have the GM part number handy ?
thanks
thanks
Agreed, it is probably the weep hole. I just did 2 water pump replacements (not on LS1s), and both were leaking at the weep hole. I used a NAPA pump, they are now gauranteed for life. No problems as of yet. I would not hesitate to use a GM pump either. Hope that helps.
thanks for the help & advice. I started the car up again the other day and it is dripping straight down from that area the arrow is pointing to.
I'll give the pump from NAPA a try for $160, the GM pump is a little pricey.
thanks again
thanks again
I thought about it but I can't justify spending that much right now on a water pump. I want to get a converter and a cam in the car so I'd rathar see the $ go towards those.
I picked up the NAPA pump ($160) and installed it on sat. The gaskets that came with it were the exact the same metal ones as oem on my 2001. Install only took about 1-1/2 hrs and was pretty damn painless. It looks like the gasket on the pass side, on the pump side not the block, may have been the culprit.
