Drag Racing Tech
Roll Cage Helps in an Accident???
Old 04-03-2005, 11:07 PM
madslow's Avatar
Default Roll Cage Helps in an Accident???
will a 6+ point roll cage help in an accident? for example losing control and the side of your car slams into a pole?
Old 04-03-2005, 11:38 PM
The Bull
DERTY's Avatar
The intention of it is to keep the body of the car from collapsing, particularly in a roll over. So, for the most part it will help protect you better than the crash bars inside the doors and the overall structure of the car. That's not to say that you will not get injured though. So, don't go robbing a bank and getting into any high speed chases.
Old 04-04-2005, 06:12 AM
BTL FED's Avatar
It should make your car safier, just make sure you have padding wherever your head could come in contact with, those bars are hard
Old 04-04-2005, 09:09 AM
12secSS's Avatar
Also if you use a harness with the roll bar/cage, otherwise you will get injured a lot more with a roll bar/cage than without one. This is because you will be bouncing around inside and not being properly restrained to one position.
Old 04-04-2005, 09:55 AM
8 second mod
Noyzee's Avatar
it should make it much safer, but i did know a kid that hit a tree, and the bar snapped and almost stabbed him!!! and another kid i know got hit and the car folded and they couldnt get out, so they had to cut the cage.
but i know i would rather have it then not.
Old 04-04-2005, 09:58 AM
madslow's Avatar
thanks for the replies
around how much weight will a roll cage add ?
Old 04-04-2005, 09:59 AM
Avengeance's Avatar
Structurally (sp?) safer.. but for you without the helmet on, much more dangerous.
Old 04-04-2005, 10:09 AM
8 second mod
Noyzee's Avatar
a 6 pt stell is aprox 80 pounds, chrommolly you would save 30 or so.
Old 04-04-2005, 11:24 AM
madslow's Avatar
of course i will be wearing a helmet when i get serious (during races only) but when cruising i wouldnt wear one. ill have bride seats with takata harnesses so ill be stuck on the seat.
how much more would chromoly be in cost over the other type of metals used? is chromoly stronger?
Old 04-04-2005, 12:32 PM
next's Avatar
Chromoly is stronger than mild steel but they are both equal in strength when you have a cage built. The reason is you use a thinner wall thickness of tube to help with the weight savings yet still hold the same strength as you would with a thicker mild steel bar.
Old 04-05-2005, 10:05 PM
AZLS1's Avatar
If you can afford that stuff then you can afford the extra cost for CroMo.
