Spohn Torque Arm & Tru Dual exhaust
Is anyone in here running a tru dual exhaust and spohn torque arm w/safety loop? I have this and was wanting to switch to a tru dual system but I dont think the exhaust will work with the safety loop.
Actually you can run true duals with x-pipe with a spohn. When I get home later on, I'll post up a pic of a setup like that. Only one I've seen, and looks like it's hurts ground clearance, but it can be done.
It can be done, and keeping decent ground clearance too. Put the X in the dip of the crossmember (on the longtube version), and run both pipes down the passenger side like you were gonna go over the axle, but dump two bullets at the axle. I've had a similar setup to this before, and there was a system built I think by Kooks that did this with magnapack mufflers. Looks really good.
Here's a pic of what I'm talking about (taken from a past thread easily accessed by a simple search )
http://www.ls1camaro.net/freehosting/dsc00734.jpg
