Drag Racing Results - Good drivers...
View Full Version : Good drivers...
kyle91z28
04-04-2005, 12:59 AM
You guys always talk about good drivers getting better times. What exactly is a good driver, especially with an automatic. When I am at the drag strip in my 91z28, I run 8.9x-9.xx in the 1/8 mile and im an auto. I start in 1st and shift manually, is there some kind of way to get better times out of my car. I shift at about 4800.. :confused:
Coach 02 A3 Z/28
04-04-2005, 08:50 AM
A good driver is someone that can drill the tree and run his number everytime down the track. The KEY is PRACTICE!
Coach
MARKSZ71
04-04-2005, 08:51 AM
pratice and learn your car,every car is diffrent
black_z
04-04-2005, 11:48 PM
Dont shift your car manually, unless you have manual valvebody.
12secondv6
04-05-2005, 12:06 PM
Yup.... knowing the car, the track... and how weather affects it.
Slight tire psi changes too
But.... practice is the key!
gator's 99TA
04-05-2005, 01:30 PM
r/t, where to stall the car up to (depending on track conditions), finding the grove, staying in the grove, and being a safe experienced driver if there is a bad situation.
practice is everything. dont manually shift. it will slow you down assuming your tranny running correctly.
