Did 02 camaros ever come with 3.73s?
Old 04-05-2005, 11:33 PM
Darkspoon's Avatar
Default Did 02 camaros ever come with 3.73s?
I have an 02 Z28 with a m6..I'm pretty sure I have 3.73 gears but I aint sure if they were put in, or if they came that way. I bought the car from a dealership with 26k miles and it had only one owner previously. I also know for a fact the speedo reads correctly. So are these stock? or were they put in and was the cpu recalibrated for the change in the speedo?
Old 04-05-2005, 11:38 PM
Tranzor's Avatar
No, M6s only came with 3.42s. If you do have 3.73s, then they were put in aftermarket and the speedo was recalibrated. What makes you think you have 3.73s?
Old 04-06-2005, 12:04 AM
Darkspoon's Avatar
at 1500 rpms im doing about 60mph..at 2000 rpms im going bout 80(in 6th gear)
I used a mph calculator and those numbers are only achievable with 3.73 gears.
Old 04-06-2005, 12:08 AM
technical's Avatar
M6 here with 3.42's. At 2k rpms in 6th I'm right at 80mph. You must have used the wrong numbers.
Old 04-06-2005, 12:12 AM
Darkspoon's Avatar
maybe..i used this site here http://www.f-body.org/gears/
Old 04-06-2005, 12:15 AM
Darkspoon's Avatar
just used another calulator...with a 3.73 rear, a .50 6th gear and a 25.68 inch tire(315/35/17) mph would be 82 mph.
Old 04-06-2005, 12:22 AM
technical's Avatar
Your tire size is smaller than my stock SS wheels...
Old 04-06-2005, 12:30 AM
Darkspoon's Avatar
arent stock SS tires 275/40/17s? thats pretty much identical in height to a 315/35/17
Old 04-06-2005, 12:33 AM
technical's Avatar
Sorry, I read your post wrong.
Old 04-06-2005, 12:37 AM
Darkspoon's Avatar
ahhh whats the deal then! according to my calculations i should have 3.73s..! is it that our tachs are way off or something??
